20-04-2023, 06:19 PM
Could anyone explain in layman’s terms how the electrical interference gets from what’s causing it into my indicator flasher unit?
Is it through the wires or through the ether?
If the wires is it via the negative earth or positive?
Ive just fitted LED lights and they all work perfect apart form the indicator dashboard light. Continuously flickers when the engines running.
I’m standard 6V set up with a dynamo that currently does not work, but that’s another’s thread.
I have tried everything I can see from on threads apart from a capacitor. If that does not work my plan is to completely wire the indicator separately to a second 6V battery. Hence my query about the ether.
Richard.
Richard.
