Pressure relief ball
#46
Continuing responses are much appreciated, if sometimes only to confirm the true mystery we have. Engine newly assembled from scrupulously cleaned parts. Oil pump parts as fully discussed above. Pressure gauges swapped, oil flow checked, gallery clear. Oil pump drive assembled as they have been before, so whilst avoiding complacency no immediate concerns. Two items mentioned by Chris that will require inspection tomorrow, and they are the blanking plugs. Not found on the gauze, but no recollection of having double checked their presence, that's just a sump off job. The other question is the gasket on top of the oil pump, described in Woodrow as joint washer. To get to the retaining nut on top of the oil pump drive shaft might access be possible by lifting the block with pistons at half stroke? On the Chummy, taking off the starter motor will allow access to the two back nuts, whereas on the Ruby splitting head from block is an engine out job. No I am not going to drop in a three cylinder Kubota to allow 76mpg!  Further reports in due course.
Pressure relief ball - by Steve kay - 03-04-2023, 06:20 PM
RE: Pressure relief ball - by Ruairidh Dunford - 03-04-2023, 06:38 PM
RE: Pressure relief ball - by Nick Lettington - 03-04-2023, 08:34 PM
RE: Pressure relief ball - by Steve kay - 03-04-2023, 08:58 PM
RE: Pressure relief ball - by squeak - 03-04-2023, 11:25 PM
RE: Pressure relief ball - by David Witton - 04-04-2023, 03:47 PM
RE: Pressure relief ball - by Steve kay - 04-04-2023, 05:39 PM
RE: Pressure relief ball - by Nick Lettington - 05-04-2023, 08:37 PM
RE: Pressure relief ball - by David Stepney - 05-04-2023, 10:38 PM
RE: Pressure relief ball - by Nick Lettington - 05-04-2023, 11:38 PM
RE: Pressure relief ball - by Steve kay - 06-04-2023, 07:07 AM
RE: Pressure relief ball - by Chris KC - 06-04-2023, 08:48 AM
RE: Pressure relief ball - by Robert Leigh - 06-04-2023, 09:12 AM
RE: Pressure relief ball - by Chris KC - 06-04-2023, 09:24 AM
RE: Pressure relief ball - by Nick Lettington - 06-04-2023, 10:22 AM
RE: Pressure relief ball - by Chris Garner - 06-04-2023, 11:56 AM
RE: Pressure relief ball - by Charles P - 06-04-2023, 12:01 PM
RE: Pressure relief ball - by Chris KC - 06-04-2023, 12:29 PM
RE: Pressure relief ball - by jpsmit - 06-04-2023, 12:41 PM
RE: Pressure relief ball - by Alan - 06-04-2023, 01:27 PM
RE: Pressure relief ball - by Nick Lettington - 06-04-2023, 05:34 PM
RE: Pressure relief ball - by David Stepney - 06-04-2023, 05:54 PM
RE: Pressure relief ball - by Ruairidh Dunford - 07-04-2023, 08:51 AM
RE: Pressure relief ball - by Steve Jones - 07-04-2023, 11:24 AM
RE: Pressure relief ball - by Reckless Rat - 07-04-2023, 11:56 AM
RE: Pressure relief ball - by Steve kay - 07-04-2023, 03:45 PM
RE: Pressure relief ball - by Ivor Hawkins - 07-04-2023, 04:12 PM
RE: Pressure relief ball - by Steve kay - 14-04-2023, 08:27 PM
RE: Pressure relief ball - by Ruairidh Dunford - 14-04-2023, 08:51 PM
RE: Pressure relief ball - by Ivor Hawkins - 14-04-2023, 08:52 PM
RE: Pressure relief ball - by Ruairidh Dunford - 14-04-2023, 08:53 PM
RE: Pressure relief ball - by Steve kay - 14-04-2023, 09:25 PM
RE: Pressure relief ball - by Ruairidh Dunford - 14-04-2023, 09:31 PM
RE: Pressure relief ball - by Chris Garner - 14-04-2023, 09:56 PM
RE: Pressure relief ball - by Ruairidh Dunford - 14-04-2023, 10:03 PM
RE: Pressure relief ball - by Nick Lettington - 14-04-2023, 10:51 PM
RE: Pressure relief ball - by Tony Press - 15-04-2023, 03:59 AM
RE: Pressure relief ball - by Steve kay - 15-04-2023, 07:27 AM
RE: Pressure relief ball - by Charles P - 15-04-2023, 07:54 AM
RE: Pressure relief ball - by Reckless Rat - 15-04-2023, 08:26 AM
RE: Pressure relief ball - by Chris KC - 15-04-2023, 09:15 AM
RE: Pressure relief ball - by Steve kay - 16-04-2023, 09:37 PM
RE: Pressure relief ball - by Chris KC - 17-04-2023, 08:22 AM
RE: Pressure relief ball - by Chris KC - 17-04-2023, 01:39 PM
RE: Pressure relief ball - by Steve kay - 17-04-2023, 09:05 PM
RE: Pressure relief ball - by Alan - 17-04-2023, 09:48 PM
RE: Pressure relief ball - by Ian Williams - 17-04-2023, 09:49 PM
RE: Pressure relief ball - by Howard Wright - 18-04-2023, 08:30 AM
RE: Pressure relief ball - by Chris KC - 18-04-2023, 08:52 AM
RE: Pressure relief ball - by Steve kay - 18-04-2023, 01:13 PM
RE: Pressure relief ball - by Jeff Taylor - 18-04-2023, 01:35 PM
RE: Pressure relief ball - by Steve Jones - 18-04-2023, 01:36 PM
RE: Pressure relief ball - by Reckless Rat - 18-04-2023, 02:22 PM
RE: Pressure relief ball - by Chris KC - 18-04-2023, 02:27 PM
RE: Pressure relief ball - by Ruairidh Dunford - 18-04-2023, 02:43 PM
RE: Pressure relief ball - by Steve kay - 18-04-2023, 08:02 PM
RE: Pressure relief ball - by Steve kay - 15-05-2023, 07:11 PM
RE: Pressure relief ball - by Tony Press - 15-05-2023, 11:29 PM
RE: Pressure relief ball - by Steve kay - 16-05-2023, 07:31 AM
RE: Pressure relief ball - by Reckless Rat - 16-05-2023, 08:57 AM
RE: Pressure relief ball - by Chris KC - 16-05-2023, 09:31 AM
RE: Pressure relief ball - by Stuart Giles - 16-05-2023, 02:05 PM
RE: Pressure relief ball - by Steve kay - 16-05-2023, 04:49 PM
RE: Pressure relief ball - by Timbo - 17-05-2023, 04:33 AM
RE: Pressure relief ball - by Steve kay - 17-05-2023, 07:17 AM
RE: Pressure relief ball - by Steve kay - 06-07-2023, 06:14 PM
