Silicone Base Gasket
Ray, from my own experience of the block to crankcase joint you will have greater success with a silicone gasket of the type the Seven Workshop sell, you will also have less chance of a bead of the Permatex sealant blocking a jet or oil way. I have tried most things over the years, paper gaskets are guaranteed to leak, silicone gloop is reasonably successful but there are risks and it will eventually leak, 518 works reasonably well for a while but again will leak eventually. As mentioned the vital thing if using a sealant or silicone gasket it total removal of oil or contaminates from the joint faces, for most other joints I have compete faith in 518 or Hylomar, both are very good products and you will not get hard globules of silicone gloop blocking anything vital.
Silicone Base Gasket - by Ian Williams - 17-04-2018, 10:35 AM
RE: Silicone Base Gasket - by Parazine - 17-04-2018, 10:39 AM
RE: Silicone Base Gasket - by Ruairidh Dunford - 17-04-2018, 10:39 AM
RE: Silicone Base Gasket - by Ian Dunford - 18-04-2018, 12:54 PM
RE: Silicone Base Gasket - by Bryan - 17-04-2018, 11:01 AM
RE: Silicone Base Gasket - by Nick Turley - 17-04-2018, 01:28 PM
RE: Silicone Base Gasket - by Chris KC - 17-04-2018, 06:54 PM
RE: Silicone Base Gasket - by Ian Williams - 17-04-2018, 08:26 PM
RE: Silicone Base Gasket - by Roland Alcock - 17-04-2018, 08:40 PM
RE: Silicone Base Gasket - by Peter Naulls - 17-04-2018, 09:19 PM
RE: Silicone Base Gasket - by Ian Williams - 17-04-2018, 10:18 PM
RE: Silicone Base Gasket - by Paulcars1 - 18-04-2018, 05:00 AM
RE: Silicone Base Gasket - by Ray White - 18-04-2018, 11:42 PM
RE: Silicone Base Gasket - by Ian Williams - 19-04-2018, 01:39 AM
RE: Silicone Base Gasket - by Colin Cheesman - 19-04-2018, 02:37 AM
RE: Silicone Base Gasket - by Ian Williams - 19-04-2018, 05:22 AM
RE: Silicone Base Gasket - by Colin Cheesman - 19-04-2018, 10:35 AM
RE: Silicone Base Gasket - by Ruairidh Dunford - 19-04-2018, 07:33 AM
RE: Silicone Base Gasket - by Dave Wortley - 19-04-2018, 09:06 AM
RE: Silicone Base Gasket - by Ruairidh Dunford - 19-04-2018, 09:10 AM
RE: Silicone Base Gasket - by Duncan Logan - 19-04-2018, 12:14 PM
RE: Silicone Base Gasket - by Dave Wortley - 19-04-2018, 12:54 PM
RE: Silicone Base Gasket - by Ruairidh Dunford - 19-04-2018, 01:23 PM
