Three bearing crank....strange middle bearing issue
That's interesting, I will try to get some photos tomorrow. I guess if it is no longer splash fed, that might explain why when hot on tickover oil pressure is 8 psi or so, while on my RP tickover oil pressure is the more usual 1 psi or so.
RE: Three bearing crank....strange middle bearing issue - by A7novice - 12-04-2023, 02:59 PM
