Three bearing crank....strange middle bearing issue
While removing pistons from crank shaft, I was surprised to find underneath the middle bearing housing an empty female threaded hole. I was expecting to find a copper pipe oil feed etc.
The engine has covered many miles in this state without any apparent problem (the reason for current strip down is a porous block).
Anyone any idea why the middle bearingĀ  should have no oil supply.?
Three bearing crank....strange middle bearing issue - by A7novice - 11-04-2023, 05:26 PM
