Zenith 26VA choke spring replacement
(15-04-2018, 04:41 PM)Stuart Joseph Wrote: Hello. There is no need to separate the lever/cam as you can 'unwind' the broken spring with a pair of pliers over the cam. Re-assembly is the reverse of disassembly (to use a phrase borrowed from Haynes).
Regards from Staffordshire - the pot-hole county.
Stuart
Thank you Stuart
The rubber band has now been replaced by the choke spring!
The technique you suggested is much the same as fitting a key to a key ring.
Roger
RE: Zenith 26VA choke spring replacement - by Roger Goldthorpe - 17-04-2018, 03:22 PM
