  • 1 Vote(s) - 1 Average
Oil leaks
Well my RN drips oil. Not an earth shattering thing to admit.
When I bought the car a few year ago I removed the sump and replaced the gauze. I replaced most of the fixing bolts and washers, applying a new gasket with the blue stuff seal.
You can see that 2 of the bolts (one each side) have had a problem in the past. I was loathe to fiddle much as I was new to A7’s. I think something like an 6/8mm bolt has been tapped in and a nut used to apply pressure to the sump plate.
On the assumption that the original bolts were meant to be tightened as much as a spanner would allow I hoped that was good enough. No torque settings of course.
Do you have any advice as to how I should proceed with the “funny” bolts or just leave alone?
I tighten the others now and then. Are there any suggested torque settings?
Oil leaks - by Old Dave - 02-04-2023, 10:17 PM
RE: Oil leaks - by Chris KC - 03-04-2023, 08:47 AM
RE: Oil leaks - by Howard Wright - 03-04-2023, 09:10 AM
RE: Oil leaks - by David Stepney - 03-04-2023, 10:50 AM
RE: Oil leaks - by Old Dave - 03-04-2023, 10:11 PM
RE: Oil leaks - by Old Dave - 04-04-2023, 08:59 PM
RE: Oil leaks - by Chris KC - 04-04-2023, 09:07 PM
RE: Oil leaks - by Old Dave - 04-04-2023, 09:34 PM
RE: Oil leaks - by Chris KC - 04-04-2023, 09:41 PM
RE: Oil leaks - by Peter Arnold - 05-04-2023, 04:02 AM
RE: Oil leaks - by "Slack Alice" Simon - 05-04-2023, 08:20 AM
RE: Oil leaks - by Steve kay - 05-04-2023, 08:30 AM
RE: Oil leaks - by Chris KC - 05-04-2023, 08:55 AM
RE: Oil leaks - by Reckless Rat - 05-04-2023, 10:26 AM
RE: Oil leaks - by Old Dave - 05-04-2023, 01:22 PM
RE: Oil leaks - by David Stepney - 05-04-2023, 01:37 PM
RE: Oil leaks - by Chris KC - 05-04-2023, 01:55 PM
RE: Oil leaks - by "Slack Alice" Simon - 05-04-2023, 04:48 PM
RE: Oil leaks - by Old Dave - 05-04-2023, 10:11 PM
RE: Oil leaks - by David Stepney - 05-04-2023, 10:25 PM
RE: Oil leaks - by Old Dave - 06-04-2023, 08:16 PM
RE: Oil leaks - by David Stepney - 06-04-2023, 09:07 PM
