  • 1 Vote(s) - 2 Average
Paint Spraying
#28
(30-03-2023, 08:39 PM)Ray White Wrote: Something which has so far been omitted is humidity.  I rely on a hygrometer.  This cheap devise is useful because if you apply paint when there is more than 50% humidity there is a risk of micro blisters that will spoil your paint a few weeks later.
Another thing to remember is that no matter what size your compressor, the air that reaches the gun must be dry.  Air as it comes out of the compressor is hot and wet so a good coalescing filter is essential as it will not only remove vapour but also oil aerosols and other micro contaminants.
Hope this helps.
50% humidity is very low. I've sprayed cellulose in winter foggy conditions and never had micro blisters. Also never had a coalescing filter.
No doubt drier is better, but I've never had those problems.
Paint Spraying - by Chris KC - 29-03-2023, 05:47 PM
RE: Paint Spraying - by Ivor Hawkins - 29-03-2023, 06:16 PM
RE: Paint Spraying - by Howard Wright - 29-03-2023, 06:24 PM
RE: Paint Spraying - by andrew34ruby - 29-03-2023, 06:37 PM
RE: Paint Spraying - by Chris KC - 29-03-2023, 06:50 PM
RE: Paint Spraying - by Reckless Rat - 29-03-2023, 07:02 PM
RE: Paint Spraying - by Hugh Barnes - 29-03-2023, 07:03 PM
RE: Paint Spraying - by Chris KC - 29-03-2023, 07:12 PM
RE: Paint Spraying - by Charles P - 29-03-2023, 07:29 PM
RE: Paint Spraying - by andrew34ruby - 29-03-2023, 08:23 PM
RE: Paint Spraying - by Chris KC - 29-03-2023, 09:50 PM
RE: Paint Spraying - by Charles P - 29-03-2023, 09:55 PM
RE: Paint Spraying - by Peter Naulls - 29-03-2023, 10:42 PM
RE: Paint Spraying - by Austin in the Shed - 30-03-2023, 08:28 AM
RE: Paint Spraying - by Dave Wortley - 30-03-2023, 08:45 AM
RE: Paint Spraying - by Charles P - 30-03-2023, 08:49 AM
RE: Paint Spraying - by Reckless Rat - 30-03-2023, 09:05 AM
RE: Paint Spraying - by Chris KC - 30-03-2023, 09:57 AM
RE: Paint Spraying - by Stuart Giles - 30-03-2023, 10:17 AM
RE: Paint Spraying - by David Stepney - 30-03-2023, 10:21 AM
RE: Paint Spraying - by JohnD - 30-03-2023, 10:30 AM
RE: Paint Spraying - by Denis Sweeney - 30-03-2023, 10:50 AM
RE: Paint Spraying - by Ivor Hawkins - 30-03-2023, 12:24 PM
RE: Paint Spraying - by Howard Wright - 30-03-2023, 01:32 PM
RE: Paint Spraying - by Ivor Hawkins - 30-03-2023, 07:56 PM
RE: Paint Spraying - by Reckless Rat - 30-03-2023, 08:21 PM
RE: Paint Spraying - by Ray White - 30-03-2023, 08:39 PM
RE: Paint Spraying - by andrew34ruby - 30-03-2023, 09:41 PM
RE: Paint Spraying - by Ray White - 04-04-2023, 06:10 PM
