  • 1 Vote(s) - 2 Average
Paint Spraying
I used to spray cellulose a lot, but now I mostly use 2 pack. Once it's been compounded, the shine loses that "glassiness" which looks wrong on an old car. The fumes are very harmful. Painting with 2 pack requires an air fed mask for safety, there have been numerous fatalities of people spraying without in an enclosed space. Even spraying in the open without a respirator with the correct filter wouldn't be a good idea.
"Standard" cellulose thinner is also known as "GunWash" which is really the only thing it's suitable for. "Best" Cellulose thinner is the stuff for spraying. If I needed something slower, I'd either add Toluene to the the paint mix or use "Anti Bloom" Cellulose thinner, which is "slower" and contains Toluene straight from the tin.
[Image: 52781346275_2cd8c62e53_k.jpg]
In the photo above, my belt has a filter regulator for the face mask air feed, it's fed by the second air hose which in turn is fed by a second compressor. My main compressor is a big three phase thing, but the air feed for the mask uses a lot of air in order to have that gentle cool breeze across your face which prevents you breathing the nasty fumes of 2 pack paint.
Paint Spraying - by Chris KC - 29-03-2023, 05:47 PM
RE: Paint Spraying - by Ivor Hawkins - 29-03-2023, 06:16 PM
RE: Paint Spraying - by Howard Wright - 29-03-2023, 06:24 PM
RE: Paint Spraying - by andrew34ruby - 29-03-2023, 06:37 PM
RE: Paint Spraying - by Chris KC - 29-03-2023, 06:50 PM
RE: Paint Spraying - by Reckless Rat - 29-03-2023, 07:02 PM
RE: Paint Spraying - by Hugh Barnes - 29-03-2023, 07:03 PM
RE: Paint Spraying - by Chris KC - 29-03-2023, 07:12 PM
RE: Paint Spraying - by Charles P - 29-03-2023, 07:29 PM
RE: Paint Spraying - by andrew34ruby - 29-03-2023, 08:23 PM
RE: Paint Spraying - by Chris KC - 29-03-2023, 09:50 PM
RE: Paint Spraying - by Charles P - 29-03-2023, 09:55 PM
RE: Paint Spraying - by Peter Naulls - 29-03-2023, 10:42 PM
RE: Paint Spraying - by Austin in the Shed - 30-03-2023, 08:28 AM
RE: Paint Spraying - by Dave Wortley - 30-03-2023, 08:45 AM
RE: Paint Spraying - by Charles P - 30-03-2023, 08:49 AM
RE: Paint Spraying - by Reckless Rat - 30-03-2023, 09:05 AM
RE: Paint Spraying - by Chris KC - 30-03-2023, 09:57 AM
RE: Paint Spraying - by Stuart Giles - 30-03-2023, 10:17 AM
RE: Paint Spraying - by David Stepney - 30-03-2023, 10:21 AM
RE: Paint Spraying - by JohnD - 30-03-2023, 10:30 AM
RE: Paint Spraying - by Denis Sweeney - 30-03-2023, 10:50 AM
RE: Paint Spraying - by Ivor Hawkins - 30-03-2023, 12:24 PM
RE: Paint Spraying - by Howard Wright - 30-03-2023, 01:32 PM
RE: Paint Spraying - by Ivor Hawkins - 30-03-2023, 07:56 PM
RE: Paint Spraying - by Reckless Rat - 30-03-2023, 08:21 PM
RE: Paint Spraying - by Ray White - 30-03-2023, 08:39 PM
RE: Paint Spraying - by andrew34ruby - 30-03-2023, 09:41 PM
RE: Paint Spraying - by Ray White - 04-04-2023, 06:10 PM
