Hole in Piston Ring
My advice is bite the bullet and do the job properly Graham. Those pistons are not a great design, the modern split skirt or slipper versions with narrow rings work so much better. The Cord rings cause excessive bore wear and sap power. If I were doing the job the block would be skimmed, honed/bored, new pistons, new valves, new guides, head skimmed, tappets refaced and profiled, and that's without looking at the bottom end which will no doubt need some remedial work.
Hole in Piston Ring - by Graham Barker - 15-03-2023, 07:51 AM
RE: Hole in Piston Ring - by John Cornforth - 15-03-2023, 10:26 AM
RE: Hole in Piston Ring - by Chris KC - 15-03-2023, 10:38 AM
RE: Hole in Piston Ring - by Robert Leigh - 15-03-2023, 01:22 PM
RE: Hole in Piston Ring - by Graham Barker - 15-03-2023, 06:53 PM
RE: Hole in Piston Ring - by Ian Williams - 15-03-2023, 09:05 PM
RE: Hole in Piston Ring - by Graham Barker - 16-03-2023, 12:39 AM
