04-03-2023, 04:51 PM
I needed to put the block on this engine at some point, so on it went, today.
The backlash on this engine is spot on and everything is newly machined etc. but you can hopefully you can still hear the clunk as the springs push the cam followers down and the cam lobe over. This noise will get more pronounced as the gears wear.
My hand reduces the impact and therefore the noise.
I hope this helps.
https://youtu.be/94gVi24e-bQ
I hope this helps.
