'29 to '31 starter motor type?
Thanks for starter motor info. I have a much rebuilt magneto engine that is proving just a bit difficult to fully complete. It fired up well, but showed no oil pressure. So turning over an engine with plugs removed has been a nessecary part of the diagnosis procedure to find out what isn’t working. A starter failing to work more than briefly suggests that there is a starter problem. If Charles can spin enough to get 40 lbs on a hc engine, I should be able to get some lbs with no compression at all!
'29 to '31 starter motor type? - by RupertW - 22-02-2023, 11:36 AM
RE: '29 to '31 starter motor type? - by Chris KC - 22-02-2023, 12:00 PM
RE: '29 to '31 starter motor type? - by RupertW - 22-02-2023, 09:22 PM
RE: '29 to '31 starter motor type? - by Steve kay - 22-02-2023, 10:39 PM
RE: '29 to '31 starter motor type? - by Dave Mann - 23-02-2023, 09:24 AM
RE: '29 to '31 starter motor type? - by Dave Mann - 23-02-2023, 02:28 PM
RE: '29 to '31 starter motor type? - by Steve kay - 23-02-2023, 11:14 PM
RE: '29 to '31 starter motor type? - by Charles P - 24-02-2023, 01:01 AM
RE: '29 to '31 starter motor type? - by RupertW - 24-02-2023, 09:40 AM
RE: '29 to '31 starter motor type? - by Dave Mann - 24-02-2023, 10:29 AM
RE: '29 to '31 starter motor type? - by Steve kay - 25-02-2023, 07:25 PM
RE: '29 to '31 starter motor type? - by Charles P - 26-02-2023, 12:05 AM
RE: '29 to '31 starter motor type? - by Steve kay - 26-02-2023, 09:29 AM
