24-02-2023, 02:00 PM
When a six volt starter is used on 12 volts the current drawn initially is higher than when using six volts, but it very quickly drops as the motor gets up to a higher speed than in the original application. My Ulsteroid is using the same motor as I fitted 20 years ago and seems very satisfactory operating from a 12 volt motorcycle battery.
