24-02-2023, 02:20 AM
your right dickie, dumping oil down the filler hole is not a great idea, I was just trying to minimise the ugly rubber pipe run. Perhaps squrting the oil onto the camshaft gear through the inspection plate is better?
The front oil gallery is plugged to minimise the delay in filling at startup.
Do you advise giving extra side clearance to number 4 big end and if so what dimension?
