Ruby half shafts
Hi , back axle removed and out diff casing opened with view to removing half shaft
Not sliding out but it appears that there are 6 "pins" , 3 of which are holding gears
 And the other 3 look as tho they locate the carrier which also acts to lock the 6 nuts.
Would someone confirm that the carrier should pull out from the 3 pins that do not
Have gears possibly with the encouragement of the (gentle) use of a drift. Or am I misreading it completely. Hopefully photo attached.
Ian
Ruby half shafts - by Ian Robert - 28-08-2017, 03:40 PM
RE: Ruby half shafts - by Stuart Giles - 28-08-2017, 04:35 PM
RE: Ruby half shafts - by Ian Robert - 28-08-2017, 05:56 PM
RE: Ruby half shafts - by Ruairidh Dunford - 28-08-2017, 06:06 PM
RE: Ruby half shafts - by Ian Robert - 28-08-2017, 07:24 PM
RE: Ruby half shafts - by Bob Culver - 28-08-2017, 08:30 PM
RE: Ruby half shafts - by Ruairidh Dunford - 28-08-2017, 09:01 PM
RE: Ruby half shafts - by Zetomagneto - 28-08-2017, 09:31 PM
RE: Ruby half shafts - by Ruairidh Dunford - 28-08-2017, 10:12 PM
RE: Ruby half shafts - by Ian Robert - 29-08-2017, 02:51 PM
