16-02-2023, 12:41 PM
(This post was last modified: 16-02-2023, 02:07 PM by Terrytuned.
Edit Reason: find more information.
Charles articale on pressure feed abit out of date as I did it some years ago, scroll down for pt2, also photos of new oil feed position avoiding bottom hose but feeding to cam and nose. You need to tap deeper through the front of the gallery past the new position and blank off with 1/4 bsp blank plug locktited in place same as rear end of gallery. The rear feed from the enlarged oil pressure outlet feeds the oil filter and outlet from fiter feeds back into the front of the gallery. Terry.
Charles you can see the oil feed setup on these photos of a finished engine. Terry
