Differential level plug
Hi All,
Some of you will have seen my Post recently dealing with a sender unit for my new A7 RN rear tank. Not comletely resolved, but decisions made and hopefully another Job jobbed soon.
While there is no tank in "Alice" obviously the vacated area needs prepping for the new installation. BIt of paint, maybe a film of Waxoyl.
Last year, a little before the July Jamboree, I did an overall service, had a dummy MOT done and I decided to check the level of oil in the differential. As you will all know the plug on the back of the diff is very close to the front of the petrol tank. So close in Alice's case that the plug fouled the tank before it could fully clear the diff. I decided that it must be OK!!! Dodgy
Anyway with the tank on holiday I decided to do the job properly and I checked the level (don't ask) Blush  The plug appears to have a fibre washer? I was expecting a copper one? From the mating face of the head the plug is 3/8 inch long (without the washer) which looks plenty. I assume that these plugs are standard length?
If I want to check the level in the future I either need a shorter plug, or I could mount the tank, say 1/4 inch further back in the car (I will need to drill the mounting holes anyway)
Do you have any advice? And should the oil level be a bit below the bottom of the hole on the diff, or do I fill until a little oil runs out? Is a complete diff oil change recommended while I am at it?
Differential level plug - by Old Dave - 04-02-2023, 05:38 PM
RE: Differential level plug - by AustinWood - 04-02-2023, 06:24 PM
RE: Differential level plug - by Old Dave - 04-02-2023, 06:32 PM
RE: Differential level plug - by Reckless Rat - 04-02-2023, 09:31 PM
RE: Differential level plug - by Peter Clayton - 04-02-2023, 10:32 PM
RE: Differential level plug - by Old Dave - 05-02-2023, 07:03 PM
RE: Differential level plug - by David Stepney - 05-02-2023, 09:53 PM
RE: Differential level plug - by Old Dave - 06-02-2023, 11:32 AM
RE: Differential level plug - by Reckless Rat - 06-02-2023, 11:41 AM
RE: Differential level plug - by Old Dave - 06-02-2023, 12:36 PM
