  • 1 Vote(s) - 5 Average
Transmisson cluster roller/ball brgs conversion
(01-02-2023, 04:00 PM)bantam turbo Wrote: RACE  ENGINE  , ( raced at Bonneville Salt Flats ) ,   w/  Turbo ,   port injection ,  (custom stainless intake / exhaust manifold ) ..   Electromotive dead fire , magnetic pickup at flywheel ,  2 coil ignition ..    (2)  bottom of crankcase to block studs ,   3/8" ARP head studs w/ thread inserts , washers ,  12 point nuts ,   Ford Zetec stainless oversize valves w/ titanium retainers , custom valve springs w/ 40  80 # pressure  , lightened followers .  Cam bushings have restricted oil flow ,   NO CAM , ( have PAUL   B  make you one, he did mine )   gear oil pump 90# pressure ,   2 piece adjustable timing gear , HADLEY billet  crank, counterbalanced , full oil pressure rod bearing ,  w/ standard size bearings .  NO RODS ..   Custom .060 forged , wedge top , pistons , (8 to 1 compression) w/ total seal rings ..  Custom head for pistons..  Solid copper head gasket..  ..   12 volt priming oil pump 50# pressure ,   side valve plate pressure oiling to springs / followers ..  Large ali. pan .  all arp engine studs w/ thread inserts ..  3 main crankcase modified for Hadley crank..  There are more details  and parts ...      All the sensors  , wiring ,  switches , relays , wiring diagram ,  ECU (Electromotive) , computor w/  tuning programing  , flywheel machined w/ 60 -2 notches for  computor timing  are available  also ..  ..  CALL 520 591 6318   STEVE..     Located in Tucson , Arizona ,  USA  ,  Shipping at cost
Not sure it is all worth the effort  Big Grin
engine for sale - by bantam turbo - 01-02-2023, 04:00 PM
RE: Transmisson cluster roller/ball brgs conversion - by Tony Press - 02-02-2023, 02:20 AM
