31-01-2023, 09:20 PM
Hi All
I’ve had a most frustrating afternoon.
I mentioned in another post that the brake light switch on the Brookfields was sticking on. What I hadn’t realised that when pressing the brake pedal both the brake and side lights came on! I only realised as the front sidelights came on as well. The sticking switch was easily solved the brake and sidelight situation not so.
I know you shouldn’t assume anything but my wiring was, to me, the obvious culprit. A couple of hours later and the wiring checked and rechecked the real problem turned out to be a faulty LED bulb. The stop tail light was bought from a good supplier (I can’t remember which one!) and has worked OK for two years!
So if you have lighting gremlins don’t immediately jump to conclusions and bulbs can turn faulty!
