Oops on crank case
Stay at 12volt
Always have a spare set of starter brushes with you.
Remove the stater annually and check it over.
Make sure that both of the bolts/studs into the crankcase are always tight.
Charles
Oops on crank case - by Erich - 10-04-2018, 04:33 AM
RE: Oops on crank case - by bob46320 - 10-04-2018, 07:16 AM
RE: Oops on crank case - by steve davidson - 10-04-2018, 07:28 AM
RE: Oops on crank case - by Zetomagneto - 10-04-2018, 08:28 AM
RE: Oops on crank case - by Ruairidh Dunford - 10-04-2018, 09:50 AM
RE: Oops on crank case - by Zetomagneto - 10-04-2018, 01:18 PM
RE: Oops on crank case - by Charles P - 10-04-2018, 12:37 PM
RE: Oops on crank case - by Zetomagneto - 10-04-2018, 01:19 PM
RE: Oops on crank case - by Chris KC - 10-04-2018, 01:19 PM
RE: Oops on crank case - by Ruairidh Dunford - 10-04-2018, 01:53 PM
RE: Oops on crank case - by Zetomagneto - 10-04-2018, 03:41 PM
RE: Oops on crank case - by Robert Leigh - 11-04-2018, 12:20 PM
RE: Oops on crank case - by JonE - 10-04-2018, 02:34 PM
RE: Oops on crank case - by Erich - 10-04-2018, 03:04 PM
RE: Oops on crank case - by AustinWood - 10-04-2018, 03:35 PM
RE: Oops on crank case - by JonE - 10-04-2018, 03:35 PM
RE: Oops on crank case - by Erich - 11-04-2018, 05:24 AM
RE: Oops on crank case - by Charles P - 11-04-2018, 06:03 AM
RE: Oops on crank case - by Ruairidh Dunford - 11-04-2018, 12:40 PM
RE: Oops on crank case - by Charles P - 11-04-2018, 01:14 PM
RE: Oops on crank case - by Ruairidh Dunford - 11-04-2018, 01:56 PM
RE: Oops on crank case - by Erich - 11-04-2018, 04:46 PM
RE: Oops on crank case - by Dave Wortley - 11-04-2018, 04:58 PM
RE: Oops on crank case - by Charles P - 11-04-2018, 09:02 PM
