cranck case problems
(22-01-2023, 12:12 PM)Duncan Grimmond Wrote: That looks like the tip of a very pointed taper tap; very tidy welding , well rescued!
Thanks Duncan. I was very pleased when ar the third attempt the weld held. I used MIG and put a few tacks on top of each other to build it up a little proud before welding through the nut.
I didn't have the same success with a broken head stud though.
cranck case problems - by phillips - 21-01-2023, 04:19 PM
RE: cranck case problems - by Ruairidh Dunford - 21-01-2023, 04:24 PM
RE: cranck case problems - by Chris KC - 21-01-2023, 05:48 PM
RE: cranck case problems - by Stuart Giles - 21-01-2023, 06:41 PM
RE: cranck case problems - by john williams - 21-01-2023, 07:46 PM
RE: cranck case problems - by Nick Lettington - 21-01-2023, 09:36 PM
RE: cranck case problems - by Duncan Grimmond - 22-01-2023, 12:12 PM
RE: cranck case problems - by phillips - 23-01-2023, 08:29 PM
RE: cranck case problems - by Stumpi - 23-01-2023, 08:59 PM
RE: cranck case problems - by Nick Lettington - 23-01-2023, 09:51 PM
RE: cranck case problems - by JohnD - 24-01-2023, 10:30 AM
RE: cranck case problems - by Martin Baker - 24-01-2023, 06:19 PM
RE: cranck case problems - by Duncan Grimmond - 24-01-2023, 07:21 PM
RE: cranck case problems - by phillips - 25-01-2023, 08:26 PM
RE: cranck case problems - by Ian Williams - 26-01-2023, 08:08 PM
RE: cranck case problems - by Robert Leigh - 27-01-2023, 07:02 PM
RE: cranck case problems - by Nick Lettington - 01-02-2025, 02:05 PM
