Oil change
(27-08-2017, 09:13 PM)Nigel was in Brittany Wrote: Thanks Keith, as i have half a can of 30 I will refill with that for the next 300 miles ,no I dont have a filter on it ,but for the last 30 years have run my RN on 20/50. I wondered about running the engine on fully synthetic as it seems more "slippery " than mineral oil , any one done it ?
Hey Nigel, Think you will find synthetic is also a multigrade with even more additives in that require the use of a filter.  Austin 7 engines with white metal bearings are very forgiving and unless you are using the RN very hard I doubt you will notice.  You would be better off having an extra pint in the pub than putting synthetic in a none filtered engine.
Good Luck
Keith
Oil change - by Nigel was in Brittany - 27-08-2017, 01:12 PM
RE: Oil change - by Derek Sheldon - 27-08-2017, 02:54 PM
RE: Oil change - by Keith Dobinson - 27-08-2017, 06:33 PM
RE: Oil change - by Nigel was in Brittany - 27-08-2017, 09:13 PM
RE: Oil change - by Keith Dobinson - 27-08-2017, 09:45 PM
