Clutch movement on my new 31 saloon
Put in a double thrust bearing at the front end and then thew crankshaft will not float as much and cause problems. The double thrust will need a washer to get the dimensions correct. I had the clucth problems until i made this change.
RE: Clutch movement on my new 31 saloon - by Pat Halahan - 10-04-2018, 08:54 AM
RE: Clutch movement on my new 31 saloon - by JonE - 11-04-2018, 08:34 AM
