Clutch movement on my new 31 saloon
Thanks for the reply. I don't quite believe the clutch is slipping however this is my best effort at explaining the symptoms:
When I select 1st with the clutch flat against the floor panel, the car wants to move and the engine revs start to die... therefore when coming to a stop and pushing the clutch in, the engine dies without increase in revs. It won't select 1st without much grinding which can't be correct surely.
Ian Williams: when you say the levers are too low, is that the foot pedal itself is to close to the floor panel?
RE: Clutch movement on my new 31 saloon - by Mk1mickey - 09-04-2018, 09:48 PM
RE: Clutch movement on my new 31 saloon - by JonE - 11-04-2018, 08:34 AM
