Rear hub woes...
Carefully cutting the hub with an angle grinder along the keyway should loosen the hub without damaging the half-shaft.
Many years ago I was foraging in a scrap yard for a Ruby half shaft. The hub would not budge. One of the workmen cut the hub along the keyway with oxy-acetalene. He was accurate and the hub came off with no 1/2 shaft damage.
Rear hub woes... - by GrahamW - 27-12-2022, 01:47 PM
RE: Rear hub woes... - by Colin Wilks - 27-12-2022, 02:06 PM
RE: Rear hub woes... - by John Mason - 27-12-2022, 04:02 PM
RE: Rear hub woes... - by David Stepney - 28-12-2022, 11:08 AM
RE: Rear hub woes... - by Ruairidh Dunford - 28-12-2022, 11:14 AM
RE: Rear hub woes... - by Ivor Hawkins - 28-12-2022, 11:17 AM
RE: Rear hub woes... - by David Witton - 28-12-2022, 01:10 PM
RE: Rear hub woes... - by Steve Jones - 28-12-2022, 01:27 PM
RE: Rear hub woes... - by GrahamW - 28-12-2022, 04:57 PM
RE: Rear hub woes... - by Ian Williams - 28-12-2022, 08:27 PM
RE: Rear hub woes... - by Colin Wilks - 28-12-2022, 08:40 PM
RE: Rear hub woes... - by GrahamW - 29-12-2022, 02:45 PM
RE: Rear hub woes... - by Ruairidh Dunford - 29-12-2022, 02:53 PM
RE: Rear hub woes... - by GrahamW - 29-12-2022, 03:09 PM
RE: Rear hub woes... - by AustinWood - 29-12-2022, 03:13 PM
RE: Rear hub woes... - by Bob Kneale - 29-12-2022, 03:24 PM
