  • 1 Vote(s) - 3 Average
Chummy headlight options/questions
Hi Rupert
As Mike says early cars had the series parallel switch and a single filament bulb. I’m not sure of the date, but around 1928???? Cars had CAV or Lucas lights with double filament bulbs…then by the early 30s a separate side light.
My RK (March 1930) has double filament bulbs, from memory the original incandescent was 5Watt and 35 Watt.
So a double contact bulb holder (Ba 15d) should allow side lights and head lights although both are not very bright.  It’s also advisable to run an earth, I use three core armoured cable.
Chummy headlight options/questions - by RupertW - 27-12-2022, 02:09 PM
RE: Chummy headlight options/questions - by Howard Wright - 27-12-2022, 06:04 PM
