Rear hub woes...
Graham, will the remaining threads clean up with a thread file ? I think you have made the mistake I did first time I tried to remove my rear hubs. Once the hub is on well and the centre bolt has been tightened but the hub will still be tight on the shaft hit the centre bolt with a heavy hammer and the shock will release the hub from the taper complete with hub puller. If the threads as shot the hub puller can be held in place with some tack welds which can be ground off once the hum is off.
John Mason.
Rear hub woes... - by GrahamW - 27-12-2022, 01:47 PM
RE: Rear hub woes... - by Colin Wilks - 27-12-2022, 02:06 PM
RE: Rear hub woes... - by John Mason - 27-12-2022, 04:02 PM
RE: Rear hub woes... - by David Stepney - 28-12-2022, 11:08 AM
RE: Rear hub woes... - by Ruairidh Dunford - 28-12-2022, 11:14 AM
RE: Rear hub woes... - by Ivor Hawkins - 28-12-2022, 11:17 AM
RE: Rear hub woes... - by David Witton - 28-12-2022, 01:10 PM
RE: Rear hub woes... - by Steve Jones - 28-12-2022, 01:27 PM
RE: Rear hub woes... - by GrahamW - 28-12-2022, 04:57 PM
RE: Rear hub woes... - by Ian Williams - 28-12-2022, 08:27 PM
RE: Rear hub woes... - by Colin Wilks - 28-12-2022, 08:40 PM
RE: Rear hub woes... - by GrahamW - 29-12-2022, 02:45 PM
RE: Rear hub woes... - by Ruairidh Dunford - 29-12-2022, 02:53 PM
RE: Rear hub woes... - by GrahamW - 29-12-2022, 03:09 PM
RE: Rear hub woes... - by AustinWood - 29-12-2022, 03:13 PM
RE: Rear hub woes... - by Bob Kneale - 29-12-2022, 03:24 PM
