  • 2 Vote(s) - 3 Average
Hi Stephen
The set up looks similar to my RK saloon.  However the RK has a thin steel post to which the timber door post is bolted. This also forms the structure to which the windscreen is bolted. On my RK the top of the tank is pretty much level and the face sits relatively tightly to the bulkhead with its lip forming a reasonable seal.  There isn’t much room above the tank, nor between the dash and the back of the tank….an SM5 switchbox only just fits!
Hope this helps?
RE: The start of my van's body build - by Howard Wright - 07-12-2022, 06:36 PM
