TO DRAIN OR NOT TO DRAIN.
Hi
I would caution against draining for too long. If the inevitable sludge and sediment is wet it's not too bad, but if it ever dries out in the tiny spaces of the radiator core it is inclined to set hard and never shift again.
I use traditional Bluecol 2 Year (Inorganic Acid Technology IAT) all year round, as much for the corrosion inhibitors as for the frost protection. The inhibitors effectiveness wanes after 2 or 3 years even though the ethylene glycol antifreeze properties carry on working. Whenever I drain and replace with fresh, the old liquid is fairly clean with no rust colouring.
If you live in a fost free climate, you can use coolant additive that just has the corrosion inhibitors.
Some say that antifreeze causes leaks, but to be honest a leak is a leak whatever you fill with.
TO DRAIN OR NOT TO DRAIN. - by Rpm - 25-11-2022, 02:07 PM
RE: TO DRAIN OR NOT TO DRAIN. - by Ivor Hawkins - 25-11-2022, 02:30 PM
RE: TO DRAIN OR NOT TO DRAIN. - by Rick F - 25-11-2022, 02:39 PM
RE: TO DRAIN OR NOT TO DRAIN. - by Ivor Hawkins - 25-11-2022, 03:08 PM
RE: TO DRAIN OR NOT TO DRAIN. - by Reckless Rat - 25-11-2022, 03:17 PM
RE: TO DRAIN OR NOT TO DRAIN. - by Rick F - 25-11-2022, 03:53 PM
RE: TO DRAIN OR NOT TO DRAIN. - by Denis Sweeney - 25-11-2022, 04:26 PM
RE: TO DRAIN OR NOT TO DRAIN. - by Austin Nippy - 25-11-2022, 07:11 PM
RE: TO DRAIN OR NOT TO DRAIN. - by John Mason - 26-11-2022, 09:42 AM
RE: TO DRAIN OR NOT TO DRAIN. - by David Stepney - 26-11-2022, 10:02 AM
RE: TO DRAIN OR NOT TO DRAIN. - by John Cornforth - 26-11-2022, 10:28 AM
RE: TO DRAIN OR NOT TO DRAIN. - by Barry Townsend - 27-11-2022, 11:02 AM
RE: TO DRAIN OR NOT TO DRAIN. - by Rpm - 27-11-2022, 12:09 PM
RE: TO DRAIN OR NOT TO DRAIN. - by Denis Sweeney - 27-11-2022, 12:28 PM
RE: TO DRAIN OR NOT TO DRAIN. - by John Mason - 27-11-2022, 01:09 PM
RE: TO DRAIN OR NOT TO DRAIN. - by Ivor Hawkins - 27-11-2022, 02:42 PM
RE: TO DRAIN OR NOT TO DRAIN. - by Graham Barker - 28-11-2022, 04:59 AM
