  • 1 Vote(s) - 2 Average
Austin wont start
#24
Hi
If you have the normal Lucas PLC type switch, it contains three separate sections: Charge rate switch, Lighting switch and Ignition switch.
The only things driven by the Ignition switch section are the Ignition, The Ignition Warning Lamp, The Petrol Gauge, the Stop Lamp and the Trafficators
It seems unlikely to me that there is a simultaneous fault in more than one section which would cause the lights to be inoperative, though anything is possible. The ignition section is internally less "chunky" than the other two and therefore less reliable after 80 years. I suggest you carefully check the wiring before condemning the switch.
Austin wont start - by pendragon374 - 10-11-2022, 10:45 AM
RE: Austin wont start - by David Stepney - 10-11-2022, 11:07 AM
RE: Austin wont start - by John Cornforth - 10-11-2022, 03:44 PM
RE: Austin wont start - by Chris KC - 10-11-2022, 04:15 PM
RE: Austin wont start - by Howard Wright - 10-11-2022, 04:35 PM
RE: Austin wont start - by Graham Barker - 10-11-2022, 07:35 PM
RE: Austin wont start - by pendragon374 - 10-11-2022, 07:41 PM
RE: Austin wont start - by John Mason - 10-11-2022, 09:15 PM
RE: Austin wont start - by Dave Mann - 11-11-2022, 11:19 AM
RE: Austin wont start - by Reckless Rat - 11-11-2022, 11:49 AM
RE: Austin wont start - by Chris KC - 11-11-2022, 02:24 PM
RE: Austin wont start - by Colin Wilks - 11-11-2022, 06:07 PM
RE: Austin wont start - by pendragon374 - 12-11-2022, 11:10 AM
RE: Austin wont start - by Chris KC - 12-11-2022, 11:35 AM
RE: Austin wont start - by Charles Levien - 12-11-2022, 12:43 PM
RE: Austin wont start - by Reckless Rat - 12-11-2022, 12:52 PM
RE: Austin wont start - by pendragon374 - 12-11-2022, 03:34 PM
RE: Austin wont start - by Reckless Rat - 12-11-2022, 03:45 PM
RE: Austin wont start - by pendragon374 - 12-11-2022, 04:22 PM
RE: Austin wont start - by John Cornforth - 12-11-2022, 05:27 PM
RE: Austin wont start - by andrew34ruby - 12-11-2022, 05:50 PM
RE: Austin wont start - by Colin Wilks - 12-11-2022, 06:42 PM
RE: Austin wont start - by pendragon374 - 16-11-2022, 07:54 PM
RE: Austin wont start - by John Cornforth - 16-11-2022, 09:46 PM
RE: Austin wont start - by Tiger - 16-11-2022, 10:35 PM
RE: Austin wont start - by Ivor Hawkins - 17-11-2022, 11:07 AM
RE: Austin wont start - by Reckless Rat - 17-11-2022, 11:47 AM
RE: Austin wont start - by Alan - 17-11-2022, 02:44 PM
RE: Austin wont start - by Austin Nippy - 18-11-2022, 10:41 AM
RE: Austin wont start - by John Mason - 18-11-2022, 04:12 PM
RE: Austin wont start - by pendragon374 - 18-11-2022, 08:09 PM
RE: Austin wont start - by Duncan Grimmond - 22-11-2022, 06:54 PM
RE: Austin wont start - by Steve Jones - 22-11-2022, 08:08 PM
RE: Austin wont start - by Peter Naulls - 22-11-2022, 09:15 PM
