Crankcase machining ???
#21
I have seen several of these castings, some of which came through Tony Betts when he bought the mouldings and residual castings from Flake Engineering.
I would expect this to be from Tony's stock or direct from Flake and not completed, due to the reasons Charles highlights above.
Crankcase machining ??? - by Bluebird7 - 14-11-2022, 10:19 PM
RE: Crankcase machining ??? - by Charles P - 15-11-2022, 12:20 AM
RE: Crankcase machining ??? - by Tony Griffiths - 15-11-2022, 02:24 AM
RE: Crankcase machining ??? - by Charles P - 15-11-2022, 08:41 AM
RE: Crankcase machining ??? - by Reckless Rat - 15-11-2022, 09:59 AM
RE: Crankcase machining ??? - by Charles P - 15-11-2022, 10:23 AM
RE: Crankcase machining ??? - by Bluebird7 - 15-11-2022, 11:06 AM
RE: Crankcase machining ??? - by Charles P - 15-11-2022, 11:21 AM
RE: Crankcase machining ??? - by Bluebird7 - 15-11-2022, 11:31 AM
RE: Crankcase machining ??? - by Charles P - 15-11-2022, 11:05 PM
RE: Crankcase machining ??? - by frequentflyer - 15-11-2022, 11:55 PM
RE: Crankcase machining ??? - by Malcolm Parker - 16-11-2022, 09:45 AM
RE: Crankcase machining ??? - by Ruairidh Dunford - 16-11-2022, 09:51 AM
RE: Crankcase machining ??? - by Charles P - 16-11-2022, 10:01 AM
RE: Crankcase machining ??? - by Bluebird7 - 16-11-2022, 10:28 AM
RE: Crankcase machining ??? - by Charles P - 16-11-2022, 11:06 AM
RE: Crankcase machining ??? - by Ruairidh Dunford - 16-11-2022, 12:14 PM
RE: Crankcase machining ??? - by bystander - 16-11-2022, 12:33 PM
RE: Crankcase machining ??? - by Charles P - 16-11-2022, 12:46 PM
RE: Crankcase machining ??? - by Ruairidh Dunford - 16-11-2022, 12:50 PM
RE: Crankcase machining ??? - by Ruairidh Dunford - 16-11-2022, 12:53 PM
RE: Crankcase machining ??? - by bystander - 16-11-2022, 12:59 PM
RE: Crankcase machining ??? - by Bluebird7 - 16-11-2022, 02:40 PM
RE: Crankcase machining ??? - by Ruairidh Dunford - 16-11-2022, 02:50 PM
RE: Crankcase machining ??? - by Charles P - 16-11-2022, 05:57 PM
RE: Crankcase machining ??? - by Tony Griffiths - 16-11-2022, 08:07 PM
RE: Crankcase machining ??? - by JoeRowing - 16-11-2022, 10:51 PM
RE: Crankcase machining ??? - by Charles P - 23-11-2022, 11:19 PM
