Crankcase machining ???
It would fit on a bridgeport with a riser and could be machined at home, for the most part. I would be tempted to find someone to do the line boring for you as alignment is more critical, the rest is fairly straight forward. A drawing would be required or you could measure from an old crank case. I would also heat soak the casting to stress relieve once roughed as depending on what material and how it was cooled it is likely to move a bit when you remove material.
Having spent a little time in consultancy dont charge your time at the normal rate or it will end up a very expensive project.....
Crankcase machining ??? - by Bluebird7 - 14-11-2022, 10:19 PM
RE: Crankcase machining ??? - by Charles P - 15-11-2022, 12:20 AM
RE: Crankcase machining ??? - by Tony Griffiths - 15-11-2022, 02:24 AM
RE: Crankcase machining ??? - by Charles P - 15-11-2022, 08:41 AM
RE: Crankcase machining ??? - by Reckless Rat - 15-11-2022, 09:59 AM
RE: Crankcase machining ??? - by Charles P - 15-11-2022, 10:23 AM
RE: Crankcase machining ??? - by Bluebird7 - 15-11-2022, 11:06 AM
RE: Crankcase machining ??? - by Charles P - 15-11-2022, 11:21 AM
RE: Crankcase machining ??? - by Bluebird7 - 15-11-2022, 11:31 AM
RE: Crankcase machining ??? - by Charles P - 15-11-2022, 11:05 PM
RE: Crankcase machining ??? - by frequentflyer - 15-11-2022, 11:55 PM
RE: Crankcase machining ??? - by Malcolm Parker - 16-11-2022, 09:45 AM
RE: Crankcase machining ??? - by Ruairidh Dunford - 16-11-2022, 09:51 AM
RE: Crankcase machining ??? - by Charles P - 16-11-2022, 10:01 AM
RE: Crankcase machining ??? - by Bluebird7 - 16-11-2022, 10:28 AM
RE: Crankcase machining ??? - by Charles P - 16-11-2022, 11:06 AM
RE: Crankcase machining ??? - by Ruairidh Dunford - 16-11-2022, 12:14 PM
RE: Crankcase machining ??? - by bystander - 16-11-2022, 12:33 PM
RE: Crankcase machining ??? - by Charles P - 16-11-2022, 12:46 PM
RE: Crankcase machining ??? - by Ruairidh Dunford - 16-11-2022, 12:50 PM
RE: Crankcase machining ??? - by Ruairidh Dunford - 16-11-2022, 12:53 PM
RE: Crankcase machining ??? - by bystander - 16-11-2022, 12:59 PM
RE: Crankcase machining ??? - by Bluebird7 - 16-11-2022, 02:40 PM
RE: Crankcase machining ??? - by Ruairidh Dunford - 16-11-2022, 02:50 PM
RE: Crankcase machining ??? - by Charles P - 16-11-2022, 05:57 PM
RE: Crankcase machining ??? - by Tony Griffiths - 16-11-2022, 08:07 PM
RE: Crankcase machining ??? - by JoeRowing - 16-11-2022, 10:51 PM
RE: Crankcase machining ??? - by Charles P - 23-11-2022, 11:19 PM
