Crankcase machining ???
(15-11-2022, 02:24 AM)Tony Griffiths Wrote: This is the sort of milling that should be able to accomplish all the machining operations - including line boring - on the A7 crankcase.
Deckel FP1 and FP2 http://www.lathes.co.uk/deckel
Or, you could go mad and find one of these: http://www.lathes.co.uk/omniversal/
As Tony may remember I used a Maho MH600, which was *just* big enough. I suspect that being just a bit smaller the Deckel FP 1 might struggle but an FP2 should be ok.
Charles
Crankcase machining ??? - by Bluebird7 - 14-11-2022, 10:19 PM
RE: Crankcase machining ??? - by Charles P - 15-11-2022, 12:20 AM
RE: Crankcase machining ??? - by Tony Griffiths - 15-11-2022, 02:24 AM
RE: Crankcase machining ??? - by Charles P - 15-11-2022, 08:41 AM
RE: Crankcase machining ??? - by Reckless Rat - 15-11-2022, 09:59 AM
RE: Crankcase machining ??? - by Charles P - 15-11-2022, 10:23 AM
RE: Crankcase machining ??? - by Bluebird7 - 15-11-2022, 11:06 AM
RE: Crankcase machining ??? - by Charles P - 15-11-2022, 11:21 AM
RE: Crankcase machining ??? - by Bluebird7 - 15-11-2022, 11:31 AM
RE: Crankcase machining ??? - by Charles P - 15-11-2022, 11:05 PM
RE: Crankcase machining ??? - by frequentflyer - 15-11-2022, 11:55 PM
RE: Crankcase machining ??? - by Malcolm Parker - 16-11-2022, 09:45 AM
RE: Crankcase machining ??? - by Ruairidh Dunford - 16-11-2022, 09:51 AM
RE: Crankcase machining ??? - by Charles P - 16-11-2022, 10:01 AM
RE: Crankcase machining ??? - by Bluebird7 - 16-11-2022, 10:28 AM
RE: Crankcase machining ??? - by Charles P - 16-11-2022, 11:06 AM
RE: Crankcase machining ??? - by Ruairidh Dunford - 16-11-2022, 12:14 PM
RE: Crankcase machining ??? - by bystander - 16-11-2022, 12:33 PM
RE: Crankcase machining ??? - by Charles P - 16-11-2022, 12:46 PM
RE: Crankcase machining ??? - by Ruairidh Dunford - 16-11-2022, 12:50 PM
RE: Crankcase machining ??? - by Ruairidh Dunford - 16-11-2022, 12:53 PM
RE: Crankcase machining ??? - by bystander - 16-11-2022, 12:59 PM
RE: Crankcase machining ??? - by Bluebird7 - 16-11-2022, 02:40 PM
RE: Crankcase machining ??? - by Ruairidh Dunford - 16-11-2022, 02:50 PM
RE: Crankcase machining ??? - by Charles P - 16-11-2022, 05:57 PM
RE: Crankcase machining ??? - by Tony Griffiths - 16-11-2022, 08:07 PM
RE: Crankcase machining ??? - by JoeRowing - 16-11-2022, 10:51 PM
RE: Crankcase machining ??? - by Charles P - 23-11-2022, 11:19 PM
