  • 1 Vote(s) - 2 Average
Austin wont start
#22
There is quite a lot of advance if the photo of the flywheel ties in with the points just opening on no. 1 cylinder. The rotor arm appears to me to be pointing straight at or a little after no 1 plug lead (with the blob of white paint) and the 1342 sequence appears correct, so either you are still 180° out (which seemed possible given you swapped 1 and 4 and it started!) or you have too much static advance.
Assuming you've sorted getting TDC on the compression stroke and are not now 180° out I would set it up bang on TDC (1/4 on the flywheel at 12:00 o'clock) and give it a go. You can tweek the static advance once it's running by twisting the distributor in its bracket, which I assume is still loose.
Small point. I'm sure you've measured it with a gauge, but the points gap looks a little bit wider than .012", but it may be the photo.
Austin wont start - by pendragon374 - 10-11-2022, 10:45 AM
RE: Austin wont start - by David Stepney - 10-11-2022, 11:07 AM
RE: Austin wont start - by John Cornforth - 10-11-2022, 03:44 PM
RE: Austin wont start - by Chris KC - 10-11-2022, 04:15 PM
RE: Austin wont start - by Howard Wright - 10-11-2022, 04:35 PM
RE: Austin wont start - by Graham Barker - 10-11-2022, 07:35 PM
RE: Austin wont start - by pendragon374 - 10-11-2022, 07:41 PM
RE: Austin wont start - by John Mason - 10-11-2022, 09:15 PM
RE: Austin wont start - by Dave Mann - 11-11-2022, 11:19 AM
RE: Austin wont start - by Reckless Rat - 11-11-2022, 11:49 AM
RE: Austin wont start - by Chris KC - 11-11-2022, 02:24 PM
RE: Austin wont start - by Colin Wilks - 11-11-2022, 06:07 PM
RE: Austin wont start - by pendragon374 - 12-11-2022, 11:10 AM
RE: Austin wont start - by Chris KC - 12-11-2022, 11:35 AM
RE: Austin wont start - by Charles Levien - 12-11-2022, 12:43 PM
RE: Austin wont start - by Reckless Rat - 12-11-2022, 12:52 PM
RE: Austin wont start - by pendragon374 - 12-11-2022, 03:34 PM
RE: Austin wont start - by Reckless Rat - 12-11-2022, 03:45 PM
RE: Austin wont start - by pendragon374 - 12-11-2022, 04:22 PM
RE: Austin wont start - by John Cornforth - 12-11-2022, 05:27 PM
RE: Austin wont start - by andrew34ruby - 12-11-2022, 05:50 PM
RE: Austin wont start - by Colin Wilks - 12-11-2022, 06:42 PM
RE: Austin wont start - by pendragon374 - 16-11-2022, 07:54 PM
RE: Austin wont start - by John Cornforth - 16-11-2022, 09:46 PM
RE: Austin wont start - by Tiger - 16-11-2022, 10:35 PM
RE: Austin wont start - by Ivor Hawkins - 17-11-2022, 11:07 AM
RE: Austin wont start - by Reckless Rat - 17-11-2022, 11:47 AM
RE: Austin wont start - by Alan - 17-11-2022, 02:44 PM
RE: Austin wont start - by Austin Nippy - 18-11-2022, 10:41 AM
RE: Austin wont start - by John Mason - 18-11-2022, 04:12 PM
RE: Austin wont start - by pendragon374 - 18-11-2022, 08:09 PM
RE: Austin wont start - by Duncan Grimmond - 22-11-2022, 06:54 PM
RE: Austin wont start - by Steve Jones - 22-11-2022, 08:08 PM
RE: Austin wont start - by Peter Naulls - 22-11-2022, 09:15 PM
