  • 1 Vote(s) - 2 Average
Austin wont start
There is no need to remove the distributor completely and then "move it round a tooth". The base plate should be left in position (that fixes the distibutor to the dynamo end casting. All you need to do is to loosen the horizontal clamping bolt, which then allows you to rotate the distributor in order to advance or retard the timing. If you have already succeeded in finding a point where the engine will start, all you then have to do is rotate the distributor body in order to find the sweet spot.
With the engine at TDC, and n°1 piston at compression, the end of the rotor arm should be pointing at the n°1 plug lead terminal inside the dizzy cap, and the points just about to open. It should start. If it doesn't then there's something else wrong. I would replace the electronic ignition unit for a set of points as a first test. You can't tell whether an electronic one is any good - they either work or they don't.
Austin wont start - by pendragon374 - 10-11-2022, 10:45 AM
RE: Austin wont start - by David Stepney - 10-11-2022, 11:07 AM
RE: Austin wont start - by John Cornforth - 10-11-2022, 03:44 PM
RE: Austin wont start - by Chris KC - 10-11-2022, 04:15 PM
RE: Austin wont start - by Howard Wright - 10-11-2022, 04:35 PM
RE: Austin wont start - by Graham Barker - 10-11-2022, 07:35 PM
RE: Austin wont start - by pendragon374 - 10-11-2022, 07:41 PM
RE: Austin wont start - by John Mason - 10-11-2022, 09:15 PM
RE: Austin wont start - by Dave Mann - 11-11-2022, 11:19 AM
RE: Austin wont start - by Reckless Rat - 11-11-2022, 11:49 AM
RE: Austin wont start - by Chris KC - 11-11-2022, 02:24 PM
RE: Austin wont start - by Colin Wilks - 11-11-2022, 06:07 PM
RE: Austin wont start - by pendragon374 - 12-11-2022, 11:10 AM
RE: Austin wont start - by Chris KC - 12-11-2022, 11:35 AM
RE: Austin wont start - by Charles Levien - 12-11-2022, 12:43 PM
RE: Austin wont start - by Reckless Rat - 12-11-2022, 12:52 PM
RE: Austin wont start - by pendragon374 - 12-11-2022, 03:34 PM
RE: Austin wont start - by Reckless Rat - 12-11-2022, 03:45 PM
RE: Austin wont start - by pendragon374 - 12-11-2022, 04:22 PM
RE: Austin wont start - by John Cornforth - 12-11-2022, 05:27 PM
RE: Austin wont start - by andrew34ruby - 12-11-2022, 05:50 PM
RE: Austin wont start - by Colin Wilks - 12-11-2022, 06:42 PM
RE: Austin wont start - by pendragon374 - 16-11-2022, 07:54 PM
RE: Austin wont start - by John Cornforth - 16-11-2022, 09:46 PM
RE: Austin wont start - by Tiger - 16-11-2022, 10:35 PM
RE: Austin wont start - by Ivor Hawkins - 17-11-2022, 11:07 AM
RE: Austin wont start - by Reckless Rat - 17-11-2022, 11:47 AM
RE: Austin wont start - by Alan - 17-11-2022, 02:44 PM
RE: Austin wont start - by Austin Nippy - 18-11-2022, 10:41 AM
RE: Austin wont start - by John Mason - 18-11-2022, 04:12 PM
RE: Austin wont start - by pendragon374 - 18-11-2022, 08:09 PM
RE: Austin wont start - by Duncan Grimmond - 22-11-2022, 06:54 PM
RE: Austin wont start - by Steve Jones - 22-11-2022, 08:08 PM
RE: Austin wont start - by Peter Naulls - 22-11-2022, 09:15 PM
