Ignition light staying on
Yes the brushes are held in with a screw on the dynamo shown, but they're not that easy to change if the dynamo is in the car, particularly if you drop one... The top one is reasonably easy, but it looks fine - the other two aren't that accessible - the 3rd brush is the one that's below the green wire in your pic. Be aware that if you remove the dynamo you will have to reset the timing. If you don't know what you're doing, have someone that does help you.
Ignition light staying on - by morrisminor - 30-10-2022, 03:13 PM
RE: Ignition light staying on - by Reckless Rat - 30-10-2022, 03:24 PM
RE: Ignition light staying on - by morrisminor - 30-10-2022, 06:10 PM
RE: Ignition light staying on - by Reckless Rat - 30-10-2022, 06:35 PM
RE: Ignition light staying on - by Peter Naulls - 30-10-2022, 07:35 PM
RE: Ignition light staying on - by Tiger - 30-10-2022, 11:34 PM
RE: Ignition light staying on - by Dave Mann - 31-10-2022, 10:39 PM
RE: Ignition light staying on - by Robin Oldfield - 02-11-2022, 06:05 PM
RE: Ignition light staying on - by Colin Wilks - 02-11-2022, 08:11 PM
