KING PIN ANGLE BIG 7
Interesting to see that Austin factory spec. for the front axle. When I reworked the big Seven front axle on my special, I set the camber to 0°. I also fabricated the radius arm setup in the photo below which allows proper adjustment of the castor angle -the 4 tubes are joined together at, and use a 1/2" rod end as the pivot on the front crossmember. BTW I was  getting a fair bit less than 5° castor when the car had the factory radius arms on it.
[Image: 40538556054_eb7a22fc3b_c.jpg]
KING PIN ANGLE BIG 7 - by Dennis Nicholas - 03-04-2018, 05:42 PM
RE: KING PIN ANGLE BIG 7 - by Parazine - 04-04-2018, 05:16 PM
RE: KING PIN ANGLE BIG 7 - by Stuart Giles - 05-04-2018, 02:19 PM
RE: KING PIN ANGLE BIG 7 - by Parazine - 06-04-2018, 02:59 PM
