Fuel consumption
#27
(10-10-2022, 11:08 PM)Vancevr Wrote: How do you tune a seven engine?
Tuning an engine in standard trim: Make sure that the points gap is properly set to 12 thou. Set timing. If you have a manual advance, the timing should be 20 degrees before TDC fully advanced. Automatic advance engines should (if memory serves me aright) be set to TDC stationary.
Check that compressions are even.
Start engine and let it warm up. Set the mixture so that the engine runs evenly. I use a Colortune (which is a transparent spark plug) to get the mixture right. The combustion should be a nice electric blue colour. Set the tickover to about 500 rpm.
My experience is with the side draft Zenith. Updraft carburetors may need more attention, but I am sure there are those with the required skills to tell you how it is done.
Hope this helps.
Fuel consumption - by Vancevr - 08-10-2022, 08:12 PM
RE: Fuel consumption - by andrew34ruby - 08-10-2022, 08:48 PM
RE: Fuel consumption - by Nick Salmon - 08-10-2022, 09:16 PM
RE: Fuel consumption - by Howard Wright - 08-10-2022, 09:17 PM
RE: Fuel consumption - by Austin in the Shed - 08-10-2022, 11:07 PM
RE: Fuel consumption - by Rick F - 08-10-2022, 11:41 PM
RE: Fuel consumption - by bob46320 - 09-10-2022, 06:38 AM
RE: Fuel consumption - by Reckless Rat - 09-10-2022, 07:34 AM
RE: Fuel consumption - by Andy Bennett - 09-10-2022, 08:33 AM
RE: Fuel consumption - by Dave Mann - 09-10-2022, 09:20 AM
RE: Fuel consumption - by Vancevr - 09-10-2022, 09:31 AM
RE: Fuel consumption - by David Stepney - 09-10-2022, 10:00 AM
RE: Fuel consumption - by Charles Levien - 09-10-2022, 01:33 PM
RE: Fuel consumption - by Parazine - 09-10-2022, 01:58 PM
RE: Fuel consumption - by AustinWood - 09-10-2022, 03:39 PM
RE: Fuel consumption - by Chris KC - 09-10-2022, 04:38 PM
RE: Fuel consumption - by Mike Costigan - 09-10-2022, 07:33 PM
RE: Fuel consumption - by Dave Mann - 09-10-2022, 09:51 PM
RE: Fuel consumption - by Howard Wright - 10-10-2022, 08:03 AM
RE: Fuel consumption - by Chris KC - 10-10-2022, 09:38 AM
RE: Fuel consumption - by Hugh Barnes - 10-10-2022, 09:52 AM
RE: Fuel consumption - by Ivor Hawkins - 10-10-2022, 01:46 PM
RE: Fuel consumption - by John H - 10-10-2022, 01:55 PM
RE: Fuel consumption - by Vancevr - 10-10-2022, 09:05 PM
RE: Fuel consumption - by David Stepney - 10-10-2022, 09:37 PM
RE: Fuel consumption - by Vancevr - 10-10-2022, 11:08 PM
RE: Fuel consumption - by David Stepney - 11-10-2022, 12:28 AM
