05-10-2022, 11:04 AM
The military two seaters I have worked on have:
Scuttle mounted tank with sender unit under the drivers side bonnet.
3 bearing engine, with semi Girling running gear, on a box saloon type frame with a unique bracket to support the silent block torque tube bracket on the rear crossmember.
17” wheels, Ruby steering wheel and instrumentation, mounted in a lozenge shaped dash.
The top tank sender and the modified bracket would be the giveaway for me.
Ruairidh
Ruairidh
