  • 1 Vote(s) - 4 Average
Mag Coil Conversion
I’ve an original Lucas coil conversion which I use when the mag isn’t working (quite often at times) I don’t use the switch panel - feed is through a separate switch. Means that you have to switch the dynamo on separately but that’s ok. All the magneto wiring is still there and you can change mag to coil in minutes.
Mag Coil Conversion - by Charles P - 25-09-2022, 04:48 PM
RE: Mag Coil Conversion - by Colin Morgan - 25-09-2022, 08:29 PM
RE: Mag Coil Conversion - by Alan - 25-09-2022, 10:41 PM
RE: Mag Coil Conversion - by leaf200 - 26-09-2022, 05:11 PM
RE: Mag Coil Conversion - by Charles P - 26-09-2022, 06:21 PM
RE: Mag Coil Conversion - by Dirk73 - 26-09-2022, 09:02 PM
RE: Mag Coil Conversion - by Charles P - 26-09-2022, 09:58 PM
RE: Mag Coil Conversion - by leaf200 - 27-09-2022, 06:49 AM
RE: Mag Coil Conversion - by Charles P - 27-09-2022, 07:52 AM
