  • 1 Vote(s) - 4 Average
Mag Coil Conversion
Having tired of recent magneto issues I decided that a mag coil conversion would be a better bet, since I can at least trouble shoot the components of a coil system, whereas replacing components in a magneto is much harder.
So I made one (as you do) using a Bosch 009 distributor, the end plate of a discarded dynamo and turning the central shaft from a broken half shaft. I’ve just bolted it on and it appears to work ok. I dare say that a Bosch 009 of indeterminate heritage (almost certainly not European) may cause a problem at some point but at least I can have spare points/cap/rotor/condenser easily and inexpensively to hand.
What’s the best way to wire a coil system into a Lucas SM3 switch panel? I may want to return to a magneto in the future. I’m thinking of simply connecting the coil feed to the dynamo switch position but is there another solution.
Thanks
Charles
Mag Coil Conversion - by Charles P - 25-09-2022, 04:48 PM
RE: Mag Coil Conversion - by Colin Morgan - 25-09-2022, 08:29 PM
RE: Mag Coil Conversion - by Alan - 25-09-2022, 10:41 PM
RE: Mag Coil Conversion - by leaf200 - 26-09-2022, 05:11 PM
RE: Mag Coil Conversion - by Charles P - 26-09-2022, 06:21 PM
RE: Mag Coil Conversion - by Dirk73 - 26-09-2022, 09:02 PM
RE: Mag Coil Conversion - by Charles P - 26-09-2022, 09:58 PM
RE: Mag Coil Conversion - by leaf200 - 27-09-2022, 06:49 AM
RE: Mag Coil Conversion - by Charles P - 27-09-2022, 07:52 AM
