21-09-2022, 02:08 PM
(This post was last modified: 21-09-2022, 02:12 PM by Steve Jones.)
Discussion at Harewood on Saturday about a similar problem on a similar car in the past came to the same conclusion as has Cliff, above. In that case, the coolant was moving around the system too fast and failing to remove heat from the engine. A restrictor in the system solved the problem.
