Suspension Modification
I can echo Andrew's comment. My RP has the factory front axle setup. Yes, it bump steers and is camber sensitive but then so is my Series 3 Landrover. Having driven my Seven over some 15K miles since I have had it I have never had any anxiety with the steering,
My first Seven was all over the road like a frightened rabbit when I first had it, but new kingpins (and resizing the axle eyes!) shackle pins and bushes and new trackrod end pins and bushes transformed the handling. It would appear that, provided the front suspension and steering is in good order, the standard setup seems to work very well.
Suspension Modification - by Mick Hanna - 16-09-2022, 01:09 PM
RE: Suspension Modification - by Reckless Rat - 16-09-2022, 01:27 PM
RE: Suspension Modification - by Howard Wright - 16-09-2022, 01:37 PM
RE: Suspension Modification - by flywheel1935 - 16-09-2022, 01:37 PM
RE: Suspension Modification - by Howard Wright - 16-09-2022, 01:56 PM
RE: Suspension Modification - by Mick Hanna - 16-09-2022, 02:52 PM
RE: Suspension Modification - by Ian Williams - 16-09-2022, 09:15 PM
RE: Suspension Modification - by John Cornforth - 16-09-2022, 09:24 PM
RE: Suspension Modification - by andrew34ruby - 17-09-2022, 08:20 AM
RE: Suspension Modification - by David Stepney - 17-09-2022, 09:33 AM
RE: Suspension Modification - by Mick Hanna - 17-09-2022, 11:23 AM
RE: Suspension Modification - by andrew34ruby - 17-09-2022, 01:38 PM
RE: Suspension Modification - by Ian Williams - 17-09-2022, 07:42 PM
RE: Suspension Modification - by David Stepney - 17-09-2022, 08:09 PM
RE: Suspension Modification - by Mick Hanna - 19-09-2022, 04:44 PM
RE: Suspension Modification - by Dirk73 - 06-10-2022, 08:23 AM
RE: Suspension Modification - by Mick Hanna - 06-10-2022, 11:23 AM
