Suspension Modification
Mick, did you try to do this with the wheels still on the axle and sitting ion the ground? I always remove front axles with wheels taken off the weight of the axle alone is then hanging on the spring. I use a modified jack under the axle to support it form below so I am in a neutral position, the shackles will then slide out without any spring deflection or axle drop.
As mentioned immobilising one shackle is a reasonable mod to improve side to side front axle swing and makes the spring effectively into a sort of panhard rod.
Mick, regarding the wandering, I would make sure that the tracking is correct, but as mentioned by others castor angle will have a lot of bearing on skittishness if the angle is to small so focus you attention checking that too.
Suspension Modification - by Mick Hanna - 16-09-2022, 01:09 PM
RE: Suspension Modification - by Reckless Rat - 16-09-2022, 01:27 PM
RE: Suspension Modification - by Howard Wright - 16-09-2022, 01:37 PM
RE: Suspension Modification - by flywheel1935 - 16-09-2022, 01:37 PM
RE: Suspension Modification - by Howard Wright - 16-09-2022, 01:56 PM
RE: Suspension Modification - by Mick Hanna - 16-09-2022, 02:52 PM
RE: Suspension Modification - by Ian Williams - 16-09-2022, 09:15 PM
RE: Suspension Modification - by John Cornforth - 16-09-2022, 09:24 PM
RE: Suspension Modification - by andrew34ruby - 17-09-2022, 08:20 AM
RE: Suspension Modification - by David Stepney - 17-09-2022, 09:33 AM
RE: Suspension Modification - by Mick Hanna - 17-09-2022, 11:23 AM
RE: Suspension Modification - by andrew34ruby - 17-09-2022, 01:38 PM
RE: Suspension Modification - by Ian Williams - 17-09-2022, 07:42 PM
RE: Suspension Modification - by David Stepney - 17-09-2022, 08:09 PM
RE: Suspension Modification - by Mick Hanna - 19-09-2022, 04:44 PM
RE: Suspension Modification - by Dirk73 - 06-10-2022, 08:23 AM
RE: Suspension Modification - by Mick Hanna - 06-10-2022, 11:23 AM
