  • 3 Vote(s) - 3.67 Average
Valve reseating
#28
This started off as a big7, now it’s a Chromidium nippy block.Different kettle of fish altogether and much easier to deal with as you can take the block off and send it to one of a number of well qualified enginers on this forum.
I certaily woul not be having seat insrts put in this block as it leaves very little margin and if Chromidium is even rarer than a Nippy engine.
Top skim to narrow the seats a bit, and very light recut.Slightly larger valves are preferable to seat inserts.
You don’t need hardened seats for unleaded, it’ a fallicy.
I probably wouln’t use this engine without a Phoenix crank for fear of something going wrong.
Valve reseating - by P J Quinn - 13-03-2018, 02:21 PM
RE: Valve reseating - by Chris KC - 13-03-2018, 03:08 PM
RE: Valve reseating - by Robert Leigh - 13-03-2018, 05:28 PM
RE: Valve reseating - by Thowdfella - 20-03-2018, 09:52 AM
RE: Valve reseating - by Jeff Taylor - 13-03-2018, 09:57 PM
RE: Valve reseating - by Derek Simmons - 20-03-2018, 12:35 PM
RE: Valve reseating - by Stuart Giles - 20-03-2018, 11:18 PM
RE: Valve reseating - by David.H - 21-03-2018, 09:35 AM
RE: Valve reseating - by Mike Costigan - 21-03-2018, 10:28 AM
RE: Valve reseating - by David.H - 21-03-2018, 11:44 AM
RE: Valve reseating - by Stuart Giles - 21-03-2018, 11:56 AM
RE: Valve reseating - by Ruairidh Dunford - 21-03-2018, 01:14 PM
RE: Valve reseating - by Stuart Giles - 21-03-2018, 03:11 PM
RE: Valve reseating - by Ruairidh Dunford - 21-03-2018, 03:35 PM
RE: Valve reseating - by Terrytuned - 21-03-2018, 06:25 PM
RE: Valve reseating - by Ruairidh Dunford - 21-03-2018, 06:32 PM
RE: Valve reseating - by Ian Dunford - 21-03-2018, 07:30 PM
RE: Valve reseating - by Ruairidh Dunford - 21-03-2018, 09:14 PM
RE: Valve reseating - by Colin Wilks - 29-03-2018, 06:28 PM
RE: Valve reseating - by Chris KC - 30-03-2018, 08:06 AM
RE: Valve reseating - by Colin Wilks - 30-03-2018, 02:49 PM
RE: Valve reseating - by Stuart Giles - 30-03-2018, 06:01 PM
RE: Valve reseating - by Colin Wilks - 30-03-2018, 06:34 PM
RE: Valve reseating - by Ian Williams - 31-03-2018, 05:09 AM
RE: Valve reseating - by Zetomagneto - 31-03-2018, 07:51 AM
RE: Valve reseating - by Ruairidh Dunford - 31-03-2018, 08:57 AM
RE: Valve reseating - by Colin Wilks - 02-04-2018, 05:59 PM
RE: Valve reseating - by Zetomagneto - 02-04-2018, 10:47 PM
