Sump studs size and thread
Firstly, Helicoils used correctly every time. I've used them for years in all sorts of applications and they do exactly what they designed to do. Re-Coil kits are not expensive and you only, really, need five sizes at most to treat most things on a Seven. However, after that (and I'm sure I might get the wrath of some) but I don't use the traditional sump set screws any more. 1/4" BSW double ended studs, Loctited into the crankcase (with Helicoils if needed), steel washers and a 1/4" BSW Nyloc nuts are now my method of choice. Coupled with a silicone sump gasket, leaks from the sump area are a now thing of the past and the sump is easily removable (although why you'd want to is a subject for another thread Wink ) and re-fitted.
Sump studs size and thread - by John Mason - 29-08-2022, 06:42 PM
RE: Sump studs size and thread - by bystander - 29-08-2022, 06:51 PM
RE: Sump studs size and thread - by JonE - 29-08-2022, 07:49 PM
RE: Sump studs size and thread - by John Mason - 29-08-2022, 08:17 PM
RE: Sump studs size and thread - by Parazine - 29-08-2022, 08:42 PM
RE: Sump studs size and thread - by bystander - 29-08-2022, 09:44 PM
RE: Sump studs size and thread - by Chris KC - 29-08-2022, 09:50 PM
RE: Sump studs size and thread - by Parazine - 30-08-2022, 10:01 AM
RE: Sump studs size and thread - by Howard Wright - 30-08-2022, 10:26 AM
RE: Sump studs size and thread - by dickie65 - 30-08-2022, 05:28 PM
RE: Sump studs size and thread - by Steve Jones - 30-08-2022, 07:29 PM
RE: Sump studs size and thread - by Charles P - 31-08-2022, 12:21 AM
RE: Sump studs size and thread - by Alan - 31-08-2022, 08:48 AM
RE: Sump studs size and thread - by John Mason - 31-08-2022, 09:11 AM
RE: Sump studs size and thread - by John Mason - 31-08-2022, 10:35 AM
RE: Sump studs size and thread - by Charles P - 31-08-2022, 12:58 PM
RE: Sump studs size and thread - by Chris KC - 31-08-2022, 05:56 PM
RE: Sump studs size and thread - by Colin Morgan - 31-08-2022, 07:59 PM
RE: Sump studs size and thread - by Colin Wilks - 01-09-2022, 09:50 AM
