Aluminium head gaskets
Not quite. If you put the spacer under the head you also increase the volume of the valve space, so the loss of compression will be greater. However, there are other reasons why you might want to put the spacer under the block. Having a gap between piston and head is beneficial to flame travel, and therefore probably thermal efficiency. If you can achieve this without increasing your valve space so much the better.
Aluminium head gaskets - by Nick Lettington - 17-08-2022, 11:43 PM
RE: Aluminium head gaskets - by Henry Harris - 18-08-2022, 01:32 AM
RE: Aluminium head gaskets - by Nick Lettington - 18-08-2022, 01:51 PM
RE: Aluminium head gaskets - by Parazine - 18-08-2022, 02:14 PM
RE: Aluminium head gaskets - by Nick Lettington - 18-08-2022, 02:40 PM
RE: Aluminium head gaskets - by Nick Lettington - 21-08-2022, 11:29 AM
RE: Aluminium head gaskets - by graham - 21-08-2022, 04:33 PM
RE: Aluminium head gaskets - by Nick Lettington - 21-08-2022, 05:54 PM
RE: Aluminium head gaskets - by Peter Sweeney - 22-08-2022, 10:42 AM
RE: Aluminium head gaskets - by Ian Williams - 22-08-2022, 11:54 AM
RE: Aluminium head gaskets - by Alan - 22-08-2022, 12:09 PM
RE: Aluminium head gaskets - by JonE - 22-08-2022, 05:12 PM
RE: Aluminium head gaskets - by Alan - 22-08-2022, 05:22 PM
RE: Aluminium head gaskets - by Ian Williams - 22-08-2022, 09:22 PM
RE: Aluminium head gaskets - by Nick Lettington - 23-08-2022, 08:20 AM
RE: Aluminium head gaskets - by Chris KC - 23-08-2022, 12:36 PM
RE: Aluminium head gaskets - by Nick Lettington - 24-08-2022, 05:47 PM
