Aluminium head gaskets
I have a LOTUS Elite fitted with a Coventry Climax engine, which has an aluminium block and head, with steel cylinder liners. Going back many years I had to run on 5 Star petrol as the engine had quite a high compression ratio. 5 star fuel became difficult to get and in order to reduce the CR and run on 4 star, I made a 0.040" thick aluminium head gasket. The standard gaskets were thin steel and thicker ones were not available at the time. I cannot remember what grade of aluminium I used but I doubt it was anything special. I had no trouble with the home made gasket over many thousands of miles. I would not hesitate to use aluminium again but thicker composite gaskets of various thicknesses are now readily available and I am getting lazy!
I also remember a garden rotovator in the family in the 1960's which had a JAP side valve engine. This had a single steel cylinder with an aluminium head and gasket.
Aluminium head gaskets - by Nick Lettington - 17-08-2022, 11:43 PM
RE: Aluminium head gaskets - by Henry Harris - 18-08-2022, 01:32 AM
RE: Aluminium head gaskets - by Nick Lettington - 18-08-2022, 01:51 PM
RE: Aluminium head gaskets - by Parazine - 18-08-2022, 02:14 PM
RE: Aluminium head gaskets - by Nick Lettington - 18-08-2022, 02:40 PM
RE: Aluminium head gaskets - by Nick Lettington - 21-08-2022, 11:29 AM
RE: Aluminium head gaskets - by graham - 21-08-2022, 04:33 PM
RE: Aluminium head gaskets - by Nick Lettington - 21-08-2022, 05:54 PM
RE: Aluminium head gaskets - by Peter Sweeney - 22-08-2022, 10:42 AM
RE: Aluminium head gaskets - by Ian Williams - 22-08-2022, 11:54 AM
RE: Aluminium head gaskets - by Alan - 22-08-2022, 12:09 PM
RE: Aluminium head gaskets - by JonE - 22-08-2022, 05:12 PM
RE: Aluminium head gaskets - by Alan - 22-08-2022, 05:22 PM
RE: Aluminium head gaskets - by Ian Williams - 22-08-2022, 09:22 PM
RE: Aluminium head gaskets - by Nick Lettington - 23-08-2022, 08:20 AM
RE: Aluminium head gaskets - by Chris KC - 23-08-2022, 12:36 PM
RE: Aluminium head gaskets - by Nick Lettington - 24-08-2022, 05:47 PM
