10-08-2022, 03:22 PM
(10-08-2022, 02:24 PM)Gordon england brooklands Wrote: I renewed my worn floatbowl needle valve recently(thank you Robert Foreman four directions to Southern Carburators web site). This has stopped the flooding problem,but the motor won’t now start without a spray of Aero Start . I am using a Solex M V 30 carburettor with 21 mm choke , 105 main jet ,55 slow running jet and a 47 gm float . I tried a 42 gm float ,this gave a fuel level just lower than the 3 mm level the Solex manual suggests. I hope someone can give me a remedy
So does the 47g float give you the necessary 3mm or is it also wrong?
Charles
