08-08-2022, 09:04 PM
(08-08-2022, 12:07 PM)john williams Wrote: I also suspect ignition timing. Put the steering column ignition lever to maximum advance, Slacken the distributor clamp, start the engine, rotate the distributor untill the engine runs at it's highest speed. This will give you slightly over advanced ignition timing, which you can alter on the steering column lever.
John, its a Ruby, they don't have advance and retard levers.
